MX3100 yellow drum damaged
  • bilyahn
    • Dec 2006
    • 1470
    Have a problem where the OPC film is peeled off of the yellow drum. Unit has 3300 color prints on it. Here are a couple of images. I had a drum with me to rebuild but after looking at the damage and not finding a cause I'm going to install a new drum unit and primary transfer belt (that was also damaged). Hoping someone has possibly seen this before. Other drums units are fine.
    Thank you for your time and effort in this matter.
    Bil
  • bilyahn
    • Dec 2006
    • 1470
    Re: MX3100 yellow drum damaged
    Quick update. Replaced drum unit and primary transfer unit also replaced yellow developer (DV unit appeared to be fine). Will check back in a week or 2 to see what the results are.
    Have a great weekend. Supposed to be 100F tomorrow! It was just in the 60's last week! LOL
    Bil
    • sharphead
      • Aug 2009
      • 285
      Never seen anything like that before no damage to main charge corona?
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        Bil
        Have seen damage like that only when dv unit rides too close to the drum.(on other brands....not Sharp) Replace the dv unit or maybe the dv spacers. How many clicks on that machine?
        • bilyahn
          • Dec 2006
          • 1470
          6500 total, 3300 color. Charge didn't seem damaged. Went back and replaced drum unit and primary transfer unit with new ones, cleaned out the DV unit and everything seemed OK so just replaced the developer (will have to check the spacers but these were new units to start with). All other drums and DV units appear to be normal with no apparent damage.
          Thanks for the comments.
          Bil
