Have a mach. with blank copies. Voltages good, charge good. DV unit not turning, have heard of problem with main drive. Anyone else seen this? Thanks.
Sharp 350/450
Mag Roller
I imagine it could be a main drive problem. But its a lot more common to find the drive end of the mag roller twisted right off.
If you roll the mag roller with your thumb, you might not notice that drive coupler doesn't turn anything.If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Check the gear on the end of the mag roller. The flat spot is probably worn completely and the gear does not turn the mag roller. If you check by turning the screw that holds the gear on you will be fooled because this will turn the mag roller regardless of the gear being worn. I have seen this many times. It usually happens when the developer is not replaced when needed. If the gear is worn then ask yourself why is the unit binding. Use a pair of pliers to turn the gear, i'm sure you will find it is worn.Comment
This happens to me when I'm trying to do too many things at the same time.
Call from customer, and break-in on the two-way, and customer talking to my back over my shoulder (dumbaxx!), and trying to fix something.....
Can everybody please just shut up for a second?!
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Copier Systems
Does te machine make any unfamiler noise
Ck dv unit out of machine manually turn it
If no luck ck dv drive unit
good luck
Andy HComment
