Sharp MX-2700n jamming when duplexing only, paper stops in upper duplex area
  • patterson70
    • May 2010
    • 599
    The MX-2700n I am working on is having the paper stop in the upper duplex area causing a jam error. If I pop open the front door to the internal finisher and use the green handle to slide the unit to the left, the paper is coming out about one inch. I can pull it out from there or from the right side after opening the right door. Could anyone seen this before and could tell me why the paper is just stopping there? I see no obstruction. The machine has about 350K on it. Maybe a drive motor? Thanks
  • harleyrider
    • Oct 2011
    • 348
    Re: Sharp MX-2700n jamming when duplexing only, paper stops in upper duplex area
    What jam code are you getting? This would help us track it down.
    • patterson70
      • May 2010
      • 599
      I'm not getting a code unfortunately, it just says "A misfeed has occured" in a pop-up box on the display. On repeatd test the originals were already out of the doc feeder when the jam occurs so I don't think the error is in the adf. It does not jam on every test run of about 7 two-sided originals , but just about every other test run.
        • 23008
        Go to simulation 22 jam history. There is a jam code. =^..^=
        • lky1978
          • Mar 2009
          • 483
          change the adu base frame . the adu base frame unit cracked or deformed due to heat by fusing.
          • patterson70
            • May 2010
            • 599
            Thank you for the information, will check on the code and change the base frame out. Is changing the base frame a bear?
            • lky1978
              • Mar 2009
              • 483
              have fun for changing the base frame.I spended 1.5 hours .
              • fajdooo
                Yust replace the sensor on the top of the right dor. You need 10min.
                • patterson70
                  • May 2010
                  • 599
                  Hello, I can't find a sensor at the top right, are you sure you are referring to a MX-2700N?
                  • patterson70
                    • May 2010
                    • 599
                    Could I ask anyone familiar with this model if there is a sensor in the door that if bad could cause the paper to stop when doing two-sided copies? It stops about an inch into the finisher but nothing is blocking it. Otherwise I will follow the advice from iky1978 to replace the adu base frame which I am not looking forward to! I guess I have to take the top of the machine off?
                    • fajdooo
                      Pleas send me an email to send you a pic of a sensor!
                      • patterson70
                        • May 2010
                        • 599
                        Could you just copy and paste it right in the reply box here? That way others can see it also. This would be appreciated!
