sharp mx-b401 error code e7-
  • Kenneth D
    • Sep 2025
    hello this is my first post.
    there is a sharp mx-b401 that is throwing an error code e7-01
    I have looked high and low on the web for an error code listing and so far have gotten nowhere. I take it these arent redily published.
    any insight would be greatly appreciated.
    thank you.
  • JustManuals
    • Jan 2006
    • 9838
    Re: sharp mx-b401 error code e7-
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • brokey
      • Oct 2011
      • 22
      Cause Image data transfer error in the MFP PWB.
      MFP PWB trouble.
      Check & Remedy Check connection of the connector and the harness
      of the MFP PWB.
      Replace the MFP PWB.
      Error cancel method Power OFF - ON
      • Kenneth D
        Thank you I have tried to power down several time to clear the code to no avail. where exactly is the MFP PWB?
        MFP PWB trouble.
        of the MFP PWB.
        • ZOOTECH
          Senior member of CRS
          • 3378
          Call a Sharp tech, he'll take care of it for you.
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            E7-01 is an image data error. Your post screams that you're an end user, so your options fall to purchasing a manual from Paul for an explanation, or a simple power cycle of your machine to clear your code.
            You're welcome to do either one. If your errors persist after a power cycle, contact your local service technician.
            • harleyrider
              • Oct 2011
              • 348
              Purchase and rtfm.
              • Kenneth D
                Thanks everyone I was hoping it was somethng I could clear, reach a plug to reseat or something that i could do to get it to fire up.
                I will leave the leatherman in my pocket.
                • mojorolla
                  The Wolf
                  • 2639
                  Leave the Leatherman at home and call a pro.
