Hi Guys,
I have a 2301 machine in the field which is leaving streaks that look very much like drum lines. It started with the black so I rebuilt the drum using the sharp kit, no problems.
Then the magenta started doing the same, so I changed that kit also, was fine for 7weeks then it started streaking again.....so I put another kit in, this time it was only fine for about a week, now its doing the same thing again.
Spoken to one sharp guy, he seems to think that the magenta dev has gone off and is overtoning and the resulting toner dust leaving the dev unit is getting on the charge grid and causing the streaks.
Now with the high cost of the coloured devs Im reluctant to chuck them in for the sake of it.....anybody else run into this problem before?
Thanks in advance!
Brad
Thanks in advance!
Brad
