Before I start, I have both Service and Parts manuals for this model ~ anyone needs them I'll send them to you for free ...
I have replaced the Sub-Frame that houses the Developer, Drum, & Fuser ... the fuser mounting broke, ie: the fuser would no longer bolt in !, there were a lot of broken / cracked pieces, the Delivery units above the fuser had some broken / cracked pieces as well ~ instead of replacing the entire assembly (exit unit 1) I'm hoping to replace the frame and remount the parts ... my question is: the second delivery unit above it is broken where the exit wheels attach ... is this unit used if you don't have a Finisher / Sorter ??? as I could just put it back in and fix only the primary exit unit ??
I know this is an older unit and probably should be replaced or thrown away ... but it's a low miler and I'm repairing it for a long time customer, any help would be appreciated !!
Thanks ... Mike
Thanks ... Mike
