code erreur F2-02 SHARP AR-5631
+ More Options
Posts
  • adnen 09
    • Sep 2009
    • 31
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    • adnen 09
      • Sep 2009
      • 31
      Re: code erreur F2-02 SHARP AR-5631
      nom
      • Akitu
        • Oct 2010
        • 2595
        Originally posted by adnen 09
        nom
        • lky1978
          • Mar 2009
          • 482
          Spanish?
          • Toner Boy
            • Aug 2007
            • 357
            I'm guessing just installed new toner, got F2-02 toner supply error, checked toner gear for spin with sim10 -gears are turning. 25-01 should read between 70 and 115.
            Bad toner cartridge or developer is starved. Replace developer and run 25-02.
            • ZOOTECH
              Senior member of CRS
              • 3375
              Originally posted by lky1978
              Spanish?
              lky1978, use the Google translator.
              • lky1978
                • Mar 2009
                • 482
                zootech, good idea....
                • Akitu
                  • Oct 2010
                  • 2595
                  French. Mine is a bit rusty after not having spoken it much since graduating high school, but I'm certified bilingual. Not necessarily fluent, but enough to get by if the need arises. I think this is the first time I've had to use it relative to the profession, however.
                  • mbcruzin
                    • Aug 2013
                    • 142
                    Ive had this error on our AR/ARM series. When you replace the developer on any of these take a moment to clean off the TD sensor. It will get coated and will throw off 25-1 or 2 readings.
