MX-2600 fax issue
  • Hoss99
    • May 2025
    [Misc] MX-2600 fax issue
    I have a customer who has 5 MX-2600's. all of them are able to send faxes but they cannot recieve them. They are using voice over IP with an analog converter. any help would be great. thanks.
  • DavePo
    • 303
    Re: MX-2600 fax issue
    Turn off ECM. Slow down reception rate to 9600 or 7200. Check bandwidth of the convertor. If it has a bandwidth saver turned on try with off.
    • Hoss99
      i have turned off the ECM and slowed down the reception with no luck. I'll try turning the bandwidth off. thanks
      • mojorolla
        The Wolf
        • 2570
        May sound silly but check the phone cords. Had a customer last week went from AT&T to Time Warner for the ISP. Time Warner used a four line phone cord and killed faxing; could send but not receive. Use a two line phone cord.
        On FXX2 and FXX3, I use these soft switch settings and they work 90% of the time:
        SW 27: 00111111
        SW 28: 11111101
        SW 29: 01000101
        SW 72: 01000110
        If that doesn't work, it is the phone line. Have the customer call the ISP and ask if the their packetization is 10 milliseconds or less OR the line supports G711 or T.38 codecs. Most likely, they will have no idea wtf you are talking about; always gives me a good chuckle.
        • Hoss99
          Thanks for the info. Hopefully it will resolve the issue
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            SW 27: 00111111
            SW 28: 11111101
            SW 29: 01000101
            SW 72: 01000110
            I just have to ask my customers if they have an analog or a digital phone line and they have no idea wtf I'm talking about. After the headache goes away it gives me a good chuckle as well.
