MX-3501 firmware update failed
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    [Electrical] MX-3501 firmware update failed
    I've got a mx-3501n in the shop that failed a firmware update. Now when it boots up I get the sharp splash screen for a couple seconds then a blank screen with "Main Program Error!! ". I can get to the CN update screen but can't get the update from USB to work with the .SFU file.
    Mystic Crystal Revelations
  • Silvertoast
    • Feb 2010
    • 270
    Re: MX-3501 firmware update failed
    rename the file emupdate.sfu plug in usb and power on.
    make sure nothing else is on the thumb drive
    • Tonerbomb
      • Feb 2005
      • 2589
      Thanks, but already tried that. No go....
      • Silvertoast
        • Feb 2010
        • 270
        just a thought but do u have a security kit installled on the copier, if so u will have to emupdate the security firmware.
        • ZOOTECH
          Senior member of CRS
          • 3375
          You might be able to access the service web page even though the boot doesn't finish and upgrade that way.
          • teklife256
            • Sep 2012
            • 164
            I have a firmware upgrade that went sideways as well. The update from the servicepage was successful. However, after the power cycled at the B402 the screen was scrambled/skewed. I can print to it and subsequent firmware updates yielded same results.
            Maybe a rom? Screen failed or bad data to screen?
