mx2314 please wait
  • ash_572
    • 523
    mx2314 please wait
    this is a fairly new machine with a 100k on the clock. 5 months old
    recently customer has noticed it stopping in the middle of a copy job saying please wait and then eventually the screen shuts off and wont turn back on. you can hear the fans still running. so then the customer has o turn off from the main switch and back on. once its turned back on it tells you to remove a paper jam in the registration area. paper just stops at the registration
    very unusual
    i have updated the firmware. there is no HDD installed on this machine.
    recently it has become more frequent
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: mx2314 please wait
    Does it have a jam code of "pri..." something? Search the forum, there has been other reports of this.
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      See Zootech's response. Check your jam code.
      • mojorolla
        The Wolf
        • 2626
        As mentioned by my 2 esteemed colleagues, a jam code is worth its weight in gold! START with the jam code, then the details.
        May want to check for a flipped drum blade. IT belt blade can flip on newer machines too.
