Sharp ar5623n network connection
  • georgereth
    • Jul 2009
    • 47
    First time after installing the machine I try to connect it with the computer I use the CDROM and first thing to make is to give the IP adress to the nic card of the machine , during the progress ( to write the ip adress i have given to the machine) the power is cut for seconds .
    After that it's impossible to write an ip adress to the machine . I run again the nic setup programm but it does not show the machine on the list
    Any ideas how to solve this problem ?
  • lky1978
    • Mar 2009
    • 483
    your network environment must to DHCP
    • georgereth
      • Jul 2009
      • 47
      Re: Sharp ar5623n network connection
      it is read first
      in the first time with the network scan tool i see the machine and i try to give the new ip adress , and in the writing progress to the copier the power is cut off . After that it is impossible to see the machine the network scan tool .
      • lky1978
        • Mar 2009
        • 483
        you can reset the copier nic card by press and hold the reset button for 5-10secs, after that reboot.
        normally i ll scan the copier ip address with sharp driver sc-scan A, if found the copier ip address, i ll log in the the copier web page and change the copier ip address.
        username:admin
        password:admin
