Sharp MX-2310u
  • GeorgeBest
    • Jul 2009
    • 526
    Sharp MX-2310u
    Hello,
    Got a customer that updated all PC's from XP to Windows7.
    Since then, not one PC can print to the Sharp MX-2310 (!?)
    It is not on a server, they print directly through IP.
    Have not made the visit yet, I was called by there Ict'er, he can't get it right . .
    Maybe a firmware update is need here ?
    Anyone ? Not much experience on this machine.
    Thanks in advance
    Gr George
  • DINGO
    • 661
    Re: Sharp MX-2310u
    the mx-2310 work fine in windows 7/8.
    • mojorolla
      The Wolf
      • 2609
      Re: Sharp MX-2310u
      Three things off the top of my head...
      1. Did they get new PCs or upgrade the OS?. Either way, your print drivers are most likely gone.
      2. XP is 32 bit, most Win 7 are 64 bit.
      3.I always thought the "U" model Sharps were non network unless you added the option.
      • Chr15tophe
        • Dec 2011
        • 42
        Re: Sharp MX-2310u
        Most likely whoever installed the driver installed the pcl6 driver instead of the saplc or vica versa depending upon what print board you have
        • lky1978
          • Mar 2009
          • 483
          go to www.sharp.net.au to download latest SPLC driver for win 7.
          The mx-2310u come with standard SPLC network printer.Do not use the pcl driver unless the machine come with PCL printer expansion kit installed.
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Re: Sharp MX-2310u
            For the older models, yes, but now the letter is practically meaningless.
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              Re: Sharp MX-2310u
              Mojorolla is right on the money, it's worth noting that 32 bit drivers can still be installed in a 64 bit architecture, but not vice-versa.
