Mx-c311 transfer belt replacement tips?
  • mrfuser
    • 1626
    Client brought the mx-c311 from another location and we are helping out for now. It needs a transfer assembly replaced and was wondering if there are any tips on doing this job.
    thanks all!
    kelly
  • mojorolla
    The Wolf
    • 2639
    Re: Mx-c311 transfer belt replacement tips?
    It is a unit. Remove old one, install the new one, calibrate and your done.
    These are by far the easiest Sharp machines when it come to maintenance.
    • MHeon71
      • Oct 2008
      • 490
      If it is the only one that needs to replace, I would purchase unit.
      But if you are buying kit. Not to bad. Front cover of pri transfer comes off by removing 1 screw and slide to left. Bottom rails and charge comes off easy enough. Remove handle on top right and cleaning section on left side. You will see 2 blue shoulder screws 1/3 from the left on front and back, remove and it will allow you to fold transfer section. Take belt off and rollers are exposed. Careful with belt, do not want kinks in them.
      Hopefully, I did not confuse you. I do not believe it would be that difficult.
      • havokprod
        • Oct 2012
        • 159
        Wrong Thread Sorry
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          Paul@justmanuals.com
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            Buy the service manual, it will save you a headache. Don't take more than a single session rebuilding it as there are so many parts you may forget where you started, especially if you're trying to do it without the manual.
