need urgent help I can not get in to sim mode AR5316 !!
  • siraphop
    • 54
    I press # interrup ---c---interup---main10----start
    but no any response .... How can I get sim mode?
    one more this m/c with light copies dv=35000
    I need urgent help.
    thank you in advance
    pop
  • bilyahn
    • Dec 2006
    • 1470
    That is the correct way to enter simulation. Sometimes the gear on the toner motor will break on similar models. When you enter sim 10 there is no sub code the toner motor just starts to turn, you can watch it with the front door open and TD cartridge removed. There are a couple of other things that cause light copies in this model. Clean the laser glass very well , it picks up quite a bit of dust for some reason. Also on the T/C unit sometimes there is grease built up on the small springs that contact the main transfer contacts. Also have had problems with springs going missing if someone has taken the transfer unit apart. And the very last is the charge unit will get dirty depending on the environment it is in. At 30K you should of also replaced the drum. If you just rebuilt it I would look at the charge unit first.
    Good luck.
    • siraphop
      • 54
      5316 sim mode
      thank you Bilyahn I ll try it now.
      • bilyahn
        • Dec 2006
        • 1470
        You are most welcome and I hope I was helpful!
