mx-2300 bad copy quality
+ More Options
Posts
  • DINGO
    • 661
    print test.pdf
  • bilyahn
    • Dec 2006
    • 1470
    Re: mx-2300 bad copy quality
    What are your developer readings and how old is your primary transfer belt. I've had issues with the toner density values being way off but that is normally just 1 color. I would try a primary transfer belt as well if you have a used one handy.
    Good luck.
    Bil
    • DINGO
      • 661
      Thank you Bily, the primary belt is new, and the charge rollers to.
      dthe reading developers are arounde the 110 to 130.
      i m thinkyng that is the developers, but in portugal the colors developers value is around 400 euros, and the costumer do not want replace.
      regards
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Dingo, when you do color adjustment, do you go into the menu and perform from the admin screen? Or do you go into simulation and perform 44-27 etc.?
        • lky1978
          • Mar 2009
          • 482
          dingo, this problem making me crazy too. Sharp pastel 1 and c-jupiter 1 got this problem.Too many "white spot" on color mode.Especially cyan and magenta. Changed the color DV just help for a while. But after apprx 10k pages (or less) has been made, problem again.
          I'm now using compatible toner that made in USA and solved this issue, so far so good at the moment.
          PS :sharp pastel2 and c-jupiter 2 much more better quality that it predecessor
          • DINGO
            • 661
            thank you friends.
            akitu, i perfomed a full color adjus in service mode.
            regards
            • gfady1
              • 16
              Dear DINGO
              I have the same problem and i don't know how to make full color adjustment
              do you mean sim 44-27 or something else
              Many thanks in advance
