Re: [SMB] Can't get SMB to work Windows 7
Using a Crossover,
Im not a sharp dealer or tech, I been a Ricoh Tech for 14 years and my sister ended up buying a business that came with a sharp copier. All I want is to set the MFP to scan to folder. I done many setups for scanning to folder on Ricoh Machines, pretty much everything should be very similar as far as setting up the folder and giving rights to the folder, disabling firewall or AV, if I disable the firewall all ports pretty much should be open and I should be able to scan.
Using a Crossover,
