MXC381 Scanner misalignment
  • Dwells
    I have a mxc381 only done about 6k total. does great quality prints, but copying and scanning on glass or through feeder the result is misaligned.
    I have gone trough the whole calibration process both service and customer processes but no joy.
    Any suggesstions gratefull.
  • bilyahn
    • Dec 2006
    • 1470
    Re: MXC381 Scanner misalignment
    Two things come to mind;
    1. Scanner unit is not square (adjustment procedure item so I would think you checked this)
    2. Scanner bed is tweaked slightly. Don't know if this adjustment is in the manual or not. Very touchy adjustment if you are not a tech, even if you are a tech proceed with CAUTION as these are red screw adjustments. Only do this as a last resort after checking everything and I mean everything else!!!
    Good luck.
    Bil
    • Dwells
      Good luck.
      Bil
      Thanks bill, and now you mention it copier has been used on a slant for the last 12 months or so. i did calibrate it on the flat though.
      Might order whole new scan assembly and advise customer re; uneven floor.
      Dave
