MX-M700 etc Doc Filing and Image send Disabling?
  • havokprod
    • Oct 2012
    • 159
    Could both of these buttons be disabled?? I have a customer that does not use those two features and is constantly pushing them, then calls to place a service call for the "copier not making copies"......(Public school with lots of users)
    Thanks in advance.
    -Aldo
    BTW if I ever have kids they are going to a private school....... the things I've seen at LASUD are mind boggling. /rant
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX-M700 etc Doc Filing and Image send Disabling?
    Thanks in advance.
    -Aldo
    After combing through the op manual, I can see nothing that would indicate they can be disabled. Tell them to place a sticky note over the buttons with the text "Do not use" and hope that covers your bases, else start billing them for frivolous calls.
    • bilyahn
      • Dec 2006
      • 1470
      Make sure your reset time is really short so that it goes back to copy mode right away is the only thing I can think of to help. Normally it is defaulted to 1 minute not sure what the shortest time is.
      Good luck.
      Bil
        • 37553
        One method is to physically disable the switches on the front panel PCB or place something under the key tops to prevent them fro being depressed.
        • Akitu
          • Oct 2010
          • 2595
          Unsolder the buttons from the control PWB so the buttons are still in working order, then if they'd like them used later tell them they'll have to purchase a new board. 2 birds with one stone! The machine works the way they want it, and no more stupid calls!
