Install Sharp on Windows 8.1 RT Arm Based Tablet
  • EXPLOITGIO
    • Oct 2013
    • 22
    Hey guys,
    Has anybody had success installing a sharp networked MFP on a Surface tablet running Windows 8.1 RT? It will not run the setup obviously but when I extract the drivers and locate the PCL driver manually it gives me the incompatible message. Also tried a generic HP PCL driver for this operating system but I get block letters.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Install Sharp on Windows 8.1 RT Arm Based Tablet
    Originally posted by EXPLOITGIO
    Hey guys,
    I would attempt to print with any of the app based printing services as opposed to a surface tablet installing PCL drivers. Yes, it's windows 8, but the coding architecture is different in relation to the fact it's a tablet.
    Under the same argument however, it's windows 8, so I can't see why the PCL would be an issue. You may have some luck by turning off the driver signing detection feature, probably a good first step to try.
    • EXPLOITGIO
      • Oct 2013
      • 22
      Yeah I turned off signature enforcement as usual with windows 8 installs started up with it off and still no dice. The prob is its an mx550 which is not supported by sharps sharpdesk mobile app for windows metro. I know its possible because the HP driver works when I force it so I'm afraid the customer may have to wait for sharp to release a 32 bit arm based driver.
      Sent from my SCH-I535 using Tapatalk
        • 23008
        We got a mass email today saying that this product is not compatible with Sharp. That's all I know. =^..^=
        • EXPLOITGIO
          • Oct 2013
          • 22
          Wonderful hahah
            • 23008
            Wonderful hahah
            Not kidding, in this one case. =^..^=
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              Not a very popular architecture for developers, sadly. Either try a different brand ARM driver or see if you can run a virtual x86.
              • EXPLOITGIO
                • Oct 2013
                • 22
                Yeah the surface even comes in a windows 8 pro variant, he must be a tight ass. I'm gonna try forcing pcl from other brands. I'll post if anything works. Thanks guys
