FNX9 - Squeak
+ More Options
Posts
  • Tech2002
    • Aug 2008
    • 334
    FNX9 - Squeak
    I've got a serious squeak with a FNX9. Tried to carefully lube
    the Belt Drive Shaft with no luck. Has anyone else come across this
    issue, if so, what was your cure?
    It's actually been doing this from almost time of installation, but has
    gotten worse.
    Appreciate any input - Thank you.
  • divad2k1
    • Sep 2010
    • 147
    Re: FNX9 - Squeak
    Usually for me, the squeak come from 1 of the 4 roller under the top cover.
    Found this thread on the forum http://www.copytechnet.com/forums/sh...9-squeaks.html
    • ZOOTECH
      Senior member of CRS
      • 3375
      Re: FNX9 - Squeak
      Some additional info here.
