AR-M257 light streaks
  • ReproKev
    • 273
    I need to clean the laser glass above the drum to hopefully fix some light streaks in the paper feed direction. I pretty much ruled out almost every other possibility - drum, blade, developing assm, transfer, fuser - all not causing the problem.
    What's the best way to do it on this machine? Does it come out, or do you have to put a rag on ruler or something to get to it? I'm a Canon tech and don't normally work on many Sharps.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: AR-M257 light streaks
    Pull toner cartridge out, one screw to release DV unit, and pull drum unit out (open side door first) - you'll see the LSU slit glass on the underneath side of cavity. Shine a flashlight after cleaning to see if it is all clean.
    • JustManuals
      • Jan 2006
      • 9838
      paul@justmanuals.com
      • ReproKev
        • 273
        So I can just reach in with a rag and clean it? OK. Thanks.
          • 23008
          Yes, you can reach right in there once the toner, developing unit, and drum unit are clear.
          Unless you're in a horribly dirty environment, you should never need to clean inside the laser. =^..^=
          • ReproKev
            • 273
            That took care of it. Thanks.
