AR-235 error code F5-02
  • ssbmi
    • Oct 2013
    • 32
    [Error Code] AR-235 error code F5-02
    I Have checked the harness connection between the lamp unit and PWB MCU, I have also made sure the connectors are good and the harness is free from nicks and damage(visiual inspection). I have then changed out the lamp unit and the PWB MCU. I still get the code after each change. I searched the Sharp idnc site for any bulletins and found MFP-TB-299. I'm sure the environment the copier is in, isn't a high humidity enviornment(air conditioned room). But am willing to try anything. Has anybody ever have this problem ? And how did you remedy it? Also Sharp don't have the "new" lamp unit in stock thats listed in the bulletin. Any ideas will be looked into.
    • 23008
    Re: AR-235 error code F5-02
    Have you metered out the lamp thermostat? =^..^=
    • oldrn
      • 166
      You haven't change the harness yet? I was able to make a bad harness work until I had a replacement by swapping ends of the cable. The end that was broken made contact when it was flattened out. The break could be internal and you won't see it. Flexing back & forth all those times and over all of those years makes us oldrn ready to break at any moment
      • ssbmi
        • Oct 2013
        • 32
        Thanks for the ideas, I'll look into both suggestions.
        • lky1978
          • Mar 2009
          • 483
          bad lamp unit harness, common fault for these old leopard series.
