f2-02 f2-64
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    [Error Code] f2-02 f2-64
    Every winter we get this.
    yes the volume is too low
    yes the humidity is too low
    yes we have changed the dev unit drum frame drums charge kits latest firmware and all new toner motors and transport pipe unit to the black developer.
    new humidity sensor
    new toner hopper foam roller
    i cant remember but i know ive done more
    any ideas? serial number starts with a 1 so i know its newer than the bulletin REP 1619a which correct the voltages so this should not be an issue
    im stumped.... has anyone had any experience with sim 44-1 and shutting off parts of process control?
    yes its over toned
    fuser is always a toner covered mess
    blacks are too black ... no background yet but ive seen background last year when it did it last winter (multiple times)
    only way to get it running again is a black pm... works for about 100 k then comes back
    I fix copiers ...Well Sorta
    • 23009
    Re: f2-02 f2-64
    Sorry, my crystal ball doesn't seem to be working.
    Sure it's a color machine, that reduces the number of models by 1/2.
    So what model is it? =^..^=
    • fireater
      • Apr 2006
      • 253
      Re: f2-02 f2-64 mx7001
      i am a dumbass!!!!! lol mx7001
      • harps05
        Field Service Engineer
        • Mar 2012
        • 112
        Might be worthwile to have a look at this. Might help, may not. Worth a try.
        MODELS: MX5500N, MX6200N, MX6201N, MX7000N, MX7001N
        SUBJECT: F2-02 OR F2-64 TROUBLE DUE TO A LOCKED TN ROLLER
        GENERAL: When operating under certain conditions, a toner replenishment (BK) failure may occur due to variations of the TN roller, causing the load torque to increase which prevents the TN Roller from rotating.
        If the TN roller fails to rotate, toner is not replenished into the DV unit (BK) correctly, resulting to F2-02 and/or F2-64 trouble.
        ACTION: To reduce the load torque on the TN roller and prevent F2-02 or F2-64 trouble, the diameter of the TN roller has been changed from
        16.5 +0.5/-0 to
        16.0 +0/-0.5.
