Persistent F2-64 Error on MX-4101N
  • CES_Imaging
    • Nov 2012
    • 65
    We have a Sharp at a customer site with a persistent F2-64 error. It seems to occur as the machine is going through its toner replenishment cycle. The developer seems to be receiving toner, so I do not think it is the toner motor. We have replaced the PCU PWB, this did not fix the error.
    Any luck getting rid of it?
  • harleyrider
    • Oct 2011
    • 348
    Re: Persistent F2-64 Error on MX-4101N
    toner sensor- dv unit?
    • ZOOTECH
      Senior member of CRS
      • 3375
      Clogged toner delivery pipe?
        • 22999
        Most of the time I just take the toner cartridge out back (out of sight) and beat on it. =^..^=
        • divad2k1
          • Sep 2010
          • 147
          One of the above !
          • mojorolla
            The Wolf
            • 2590
            Pull the toner cart and run SIM 25-1. The top set of numbers indicate how much toner is in each developer unit. The lower the number, the more toner is in the DV unit. If the number is very low 20-30 dv material will be needed to be replaced. If it is above 200, there is not enough toner and the machine pulls dv; again dv material will be needed.
            Off the top of my head, if the reading is below 73 or above 200, those codes appear.
            As mentioned above, check the feed pipe is not packed or the toner cart is not sticking. Two very common issues with Sharp.
            Also make sure the customer is storing the backup toner flat. We had a customer storing it on end which caused several F2 codes.
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • CES_Imaging
                • Nov 2012
                • 65
                I'm headed out to the customer this morning. I'll let you know what happens.
                I know it isn't the DV sensor, as we tried replacing the DV unit.
                • teklife256
                  • Sep 2012
                  • 164
                  This error came up on a similar machine a couple months back. If I recall correctly I shook the toner and cleared code.
                  Were you able to come come up with a solution?
