Noisy Fan
  • tcypy1961
    • 773
    Noisy Fan
    On this Sharp AR-M 350 the customer is complaining about a noisy fan. The fan in question is the one above the fuser. Should this fan be running at all times or does it only come on at certain times? I ask this because I removed the cover to inspect the fan and noticed it wasn't running. The customer always stated that the noise sounds like an airplane taking off, and it is made when the machine is just sitting unused, and also when in use, but it doesn't happen all the time. Thank you for any help given.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Noisy Fan
    If the machine has a lot of miles on it, and the delivery turn over unit has not been changed - replace it.
    • harleyrider
      • Oct 2011
      • 348
      Re: Noisy Fan
      I don't have that model handy right now but if I remember correctly those fans cycle on and off. Like said above those units go bad. The LSU can make that noise also. All fans can and will go bad.
      • JustManuals
        • Jan 2006
        • 9838
        Re: Noisy Fan
        Paul@justmanuals.com
          • 23008
          Re: Noisy Fan
          That's a common fan to fail. It sits directly over the fuser and gets roasted ... for years. You can get the fan separately, but if you're going to the trouble, replace the delivery turnover assembly. It's probably crumbling too. Maybe you caught it in time.
          Failure of this fan usually results in the drum cleaning unit fusing solid:
          Chip out the cleaning unit. Replace the delivery/turnover fan (NFANP0069FCZZ), cleaning auger (NROLP1354FCZZ), gear 14T (NGERH1417FCZZ), drum (AR-451DR), lower seal, & blade (AR-450KC1).
          Or maybe H2-01 errors.
          Reform thermistors. Tighten lamp terminal screws. Also check that delivery fan runs at low speed during idle.
          The same fan is used in the left inner door, and fails there too.
          By the way, these fans are supposed to run all the time. Low speed during idle, high speed during printing. When they start to fail the fan will stall out during idle, or buzz, vibrate, or screech. You'll feel the vibration in the delivery/turnover top cover. =^..^=
          • nmfaxman
            • 1702
            Re: Noisy Fan
            You can always clean the blades and oil the bearings for a short term fix and verify that is the fan causing the noise.
            If it comes back, clean and lube again and order a new one.
            There are alternatives than just throw a new one in and throw away a repairable part.
              • 23008
              Re: Noisy Fan
              If you've ever chiseled out one of these cleaning units, you wouldn't want to take the risk. =^..^=
