Sharp MX-2640N SPPD3_N Sensor Jamming
  • I.D.S.
    • 21
    [Jamming] Sharp MX-2640N SPPD3_N Sensor Jamming
    Good morning my fellow techs,
    I've come across an intersting problem yesterday. On a Sharp MX-2640N's document feeder, every page I attempted to run through jammed upon contact with the SPPD3_N sensor (About 90 times in all, from what the machine history showed). I read Dave's post about the same issue on a MX-M453N (http://www.copytechnet.com/forums/sh...-DSPF-jam-code) and after checking the SRRC clutch, that worked fine. I checked all the surrounding motors and those seem to be good as well. After checking the sensor itself in a test, it worked fine too. All of this done, I've decided to go ahead and change the sensor any way just to elimate that as the issue. Strange thing is, I can't locate the part number for it. There's a picture of it in the parts guide but when the part number is entered on SharpNet it shows up as a "Bearing". Can anyone shed some light on this issue? Any help would be greatly appreciated.
    P.S. - Yes, I did call tech support and yes, I did update the firmware.
  • harleyrider
    • Oct 2011
    • 348
    Re: Sharp MX-2640N SPPD3_N Sensor Jamming
    Is it section 8 item#17 part#VHP6P1A73A+-18
    • I.D.S.
      • 21
      Awesome! Thank you so much!
      • DavePo
        • Jul 2008
        • 305
        Just a FYI that number has been updated to VHPGP1A73AR-1
        • I.D.S.
          • 21
          Yup! As soon as I entered the part number from the guide, SharpNet automatically changed it to the updated number. Thanks!
          • glewisme
            • Nov 2009
            • 240
            Has anyone torn one of theses down to be able to replace the SPPD3 sensor.??????? Doesn't look too fun at all.
            • I.D.S.
              • 21
              Nope. I haven't fully taken it apart but I did remove the front and rear cover of the DSPF and that was a struggle. I'm definitely not looking forward to this one...
              • glewisme
                • Nov 2009
                • 240
                Removing the entire feed assembly isn't really too difficult. The top cover that houses all the sensors is the real problem. I get it to the point it's ready but there's just one spot that's hung up and I just cant seem to locate where. I'm afraid to break it if I get any more forceful.
                • glewisme
                  • Nov 2009
                  • 240
                  Actually access to the sensor is easy once the feed unit is removed. Flip it over and loosen the two anchor screws for the steel pf guide ( w/ white mylar) pivot it out of the way and there it is right there out in the open...
                  • glewisme
                    • Nov 2009
                    • 240
                    I.D.S
                    Let me know how it worked out for you...
                    • lcastillo5
                      • Jun 2008
                      • 32
                      I've had that problem 3 times already, I swapped sppd3 sensor with sppd4 sensor and still had the same problem. It's not the sensors it's the ADF driver board.
                      • copyguy1
                        • Jul 2011
                        • 142
                        Sharp has had an issue with all the sensors in these machines there is a tech bulletin about it.
                        • lcastillo5
                          • Jun 2008
                          • 32
                          Yeah, I've seen it and tried replacing all sensors with the new part number ones, still had to replace driver board.
                          • Hansen88
                            • 1068
                            I know this is old but I had a SPPD3_N jamming issue also and it turned out to be the doc feed board also.
