sharp mx 453 light prints and copies
  • rbaldwin
    • May 2011
    • 5
    Seem to have a problem with mx 453 machine. Internal prints and copies are super light dev maintenance kit and drum have been changed and stir same problem.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: sharp mx 453 light prints and copies
    How dusty is the LSU slit glass?
      • 23008
      Have you emergency stopped the machine yet to see if you're getting a properly developed image on the drum? =^..^=
      • Silvertoast
        • Feb 2010
        • 270
        i have been having this same problem with a 453. full pm and copies look excellent for around 5-6k then goes light again. my next step is to repl dv unit. and see what happens
        • lky1978
          • Mar 2009
          • 483
          Already try to clean the Toner Density sensor?
          • Silvertoast
            • Feb 2010
            • 270
            if your asking me, then yes i did. had one of the smaller sharps (cant remember the model, the replacement for the 237 257 ect..) kept doing this also and turned out to be the pcu pwb. hope it doesnt come to this so tryin a dv unit first
            • spanky
              • Sep 2012
              • 468
              change sim 46-19 AE_MODE from mode 2 to mode 1
              • AGI
                • Jul 2011
                • 17
                have anyone found the issue with this problem?
                Authorized Kyocera and Konica Minolta Dealer in NJ
                Sales Site
                Customer Site
                • jp74msj55
                  • Oct 2014
                  • 149
                  I have seen this problem and changed the process unit out with the maintenance kit and Drum at same time.
                  Good luck!!!
                  • jp74msj55
                    • Oct 2014
                    • 149
                    Make sure your 25-2 value is good when you change developer.
                    • boutn
                      • Jun 2016
                      • 547
                      replace transferroller, clean sensor on the transferunit, do a 44-2, should be ok then.
                      Good luck
                      • boutn
                        • Jun 2016
                        • 547
                        replace transferroller, clean sensor on the transferrunit and do a 44-2.
                        Should be ok then.
                        Good luck!
                        • AGI
                          • Jul 2011
                          • 17
                          yes have changed drum pm n developer. work for awhile then comes back. 70k on pm parts
                          Sales Site
                          Customer Site
                          • spanky
                            • Sep 2012
                            • 468
                            I had an MX-365N with the same problem.
                            I backed up all of the settings and ran sim 67-17 to reset the machine to factory settings.
                            I then pushed the backed up settings back into the copier and had no more problems.
                            • repn1999
                              • May 2010
                              • 310
                              These machines seem to not make the pm cycles using aftermarket drums and toner...Sorry they just dont. First I would check the high voltage output and adjust it to what you get in SIM 8. Next I recommend changing the dv and drum and mk kit all at once with oem stuff. MAKE sure to install the little clear seals that go on the front drum seal on each end. If you dont it will pull dv sooner or later. next clean or replace the transfer roller. I personally just wash them with warm water and a little tad of lotion free soap and then dry. clean the density sensor in the transfer unit while you have it apart along with the sawtooth grids in the unit. Then recalibrate the machine. 44-2 and then 46-24. If this doesnt fix it or it happens again.....replace the HV pwb and then do the hv adjustment as described in the manual.
