Sharp MX 2300n printing quality
  • gfady1
    • 16
    Dear all
    I got a sharp mx 2300n and i have a bad quality in both printing and coping .. i think i need color adjustment and calibration
    i also installed a new 4 drum as i thought that its a drum problem but nothing changed...
    for any help i'll be totally thankful
  • lky1978
    • Mar 2009
    • 483
    how many pages has been made for color and black?
    Have you change main corona, developers, primary transfer belt.
    Better you upload some samples for us.
    • JustManuals
      • Jan 2006
      • 9838
      Re: Sharp MX 2300n printing quality
      Paul@justmanuals.com
      • gfady1
        • 16
        Thanks lky1978
        the MX 2300 copied 73482 black copy and 38493 color copy
        No i didn't change the DV nor the corona ..
        i only tried to execute the sim 67-24 and 44-26
        please find the attached for the original image and the copies before and after the execution of the calibration (67-24) and 44-26
        Many thanks for your support and waiting your advice
        • MHeon71
          • 489
          I would try a complete calibration. Also when you do the 67-24, I try to use good paper like Hammermill 28 lbs 96 bright and within this TC you should redo the steps 4 times. I am not sure if you typed the wrong TC but I would do TC 46-24 when I do TC 67-24.
          If you do not have a manual, you should get one. Sharp lists the necessary steps and the sequence that they should be done in. Sharp also gives maintenance counters for each unit. So you may be doing color PM today and next week or next month it will need a black PM, pri transfer kit, fuser kit etc. Color and black PM are not the same on Sharp copiers. Color for this copier is 60K and black is 100K and other units are higher.
          • lky1978
            • Mar 2009
            • 483
            Can give me your email? I ll send something for you.And also make sure firmware was up to date.
            Merry Christmas to you all!!!!
            • gfady1
              • 16
              Many thanks for your concern
              My email gfady1@hotmail.com
              Merry Christmas for you
