MX5500N Black looks purple
  • maf49
    • 9
    We have an MX5500N that whenever we print or copy in color the black looks purple. When we do B/W the black looks fine. We have run all the calibrations for color quality. Nothing seems to change it. Any ideas would be greatly appreciated.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MX5500N Black looks purple
    What you are most likely seeing is process black; a CYM combination to form a close approximation of black. Most printing drivers allow you to choose between pure black and process black.
    • maf49
      • 9
      No it is more than just that. I have other similar machines here in the shop that dont do this. It does it a great deal on the grey scale more than the solid blacks when we use a test chart. Also the blues are coming out really dark purple.
        • 23008
        It sounds like you've got a yellow problem.
        Composite black is equal parts yellow, cyan, magenta.
        Most blues have cyan and yellow
        If yellow is missing composite black becomes only cyan + magenta = purple. =^..^=
        • maf49
          • 9
          Yeah I ran some single color sky shots and the yellow looks weak. I swapped drums with no change. I will have to order the DV and try that. I think that may be the issue.
