sharp mx4101n
  • rods
    • 23
    sharp mx4101n
    Trying to print on 11x17 heavy paper in pamphlet mode, I get message 2-sided printing cant be done at the specified paper type but walk up it will let me do it.Would this be a print driver limitation.
  • Jaws
    • Oct 2007
    • 235
    Re: sharp mx4101n
    It wont do it in Heavy paper mode. Depending on weight you can just set it to plain and will work fine.
      • 23007
      Re: sharp mx4101n
      Yeah, the limitation is probably the media type passing through the folder. Check the machine specs on the folding option. I think you'll find that the heaviest foldable media is 28# or less. =^..^=
      • mojorolla
        The Wolf
        • 2606
        Re: sharp mx4101n
        It should have an FN10 finisher so up to 15 sheets of 28lb stock as blackcat mentioned. You can use 1 sheet of cover stock up to 110lb.
        • rods
          • 23
          Re: sharp mx4101n
          I understand what you guys are saying and it has an fn10 but why does it let you do it in copy mode
          • ZOOTECH
            Senior member of CRS
            • 3375
            Re: sharp mx4101n
            Because the the tray is not set up for 'heavy' paper in copy mode?
            • rods
              • 23
              Re: sharp mx4101n
              The tray is set uo for heavy paper in copy and print mode and will do the job in copy mode but not in print mode
