MX-M4101N - PDF file does not show up on USB
  • Jaws
    • Oct 2007
    • 236
    When trying to print from USB stick or after scanning to it you can t see the PDF file. It's there but you can only see folders? No files! is there a setting for this? Is there a firmware to fix this?
    Thx
    JAWS!
  • mojorolla
    The Wolf
    • 2624
    Re: MX-M4101N - PDF file does not show up on USB
    You need the Postscript option installed to see that file type.
    SIM 22-10 lists all installed options.
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Sharps also have difficulty reading anything but the root folders of flash drives. Move your intended file to the root folder of your flash drive and you should be able to see it. Depending on the file type the postscript kit may not be necessary.
