When trying to print from USB stick or after scanning to it you can t see the PDF file. It's there but you can only see folders? No files! is there a setting for this? Is there a firmware to fix this?
Sharps also have difficulty reading anything but the root folders of flash drives. Move your intended file to the root folder of your flash drive and you should be able to see it. Depending on the file type the postscript kit may not be necessary.
