Sharp Mx2600n
  • bobe
    • Oct 2011
    • 38
    Sharp Mx2600n
    hello,
    Sharp MX2600N, only color is working is yellow anything else is blank ( I don't have cyan, magenta and black ). Who has the same issue or have any idea please reply me. I thinking to replace the transfer belt . Thanks
    • 23008
    Re: Sharp Mx2600n
    Have you done a stop test yet on an image with all four colors? Examine the primary transfer belt. What colors are properly developed? =^..^=
    • CorbinDallas
      • Mar 2012
      • 56
      Laser shutters open on that series in slightly delayed sequence starting with yellow. Try removing the shutter assembly for one of the other colors to see if it prints. Underneath the DV Drum section has one screw and slides out the front.
      • eliza925994
        • Jun 2014
        • 14
        Re: Sharp Mx2600n
        Having problems getting a Sharp MX-2600N photocopier to print properly. I understand that technically you need to install the PostScript (PS3) expansion kit to the copier to allow printing from Macs, however there are a few workarounds wch have been suggested wch have had partial success.
        removes chromatic colour from a scanned image,reducing the data size for compact storage and enhancing the legibility of B/W text to improve the text recognition rate before OCR.
        Kyocers Copiers in Gold Coast
          • 23008
          Re: Sharp Mx2600n
          What part was the question? Or is this just spam? =^..^=
          • ZOOTECH
            Senior member of CRS
            • 3375
            Re: Sharp Mx2600n
            I think you nailed it BC; it seems we're seeing more and more of this type of questionable advertising.
