Toner issue
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 167
    [Misc] Toner issue
    My machine sharp AR-651 required toner for bad luck I used RICOH toner which caused trouble as:
    a ghost image but it does not appear for first copy it appear after many copy.
    Can you help me to get ride of this problem and RICOH toner is the issue?
    Thanks for help!
    • 22927
    Re: Toner issue
    As the Master Of The Obvious, I have to ask: Are you really serious? Do you really wonder if Ricoh toner is not compatible with Toshiba developer? (The AR-651 is a Toshiba build).
    Do I really have to suggest vacuuming out the toner hopper, changing the developer, and installing Sharp AR-651 toner? I think you're smart enough to know this. =^..^=
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: Toner issue
      I don't think he is........... check some of his other posts
      Mystic Crystal Revelations
        • Mar 2012
        • 167
        Re: Toner issue
        As is in your (laughter) comment the problem has solved by making solid copies and install new toner that is all not need to your laughter ok my ........!
