SHARP MX-C311 ADF REMOVAL
  • ameritech
    • 96
    Hey everyone, has anybody remove the adf on this machine before? Seems like it has to be remove with the scanner
    assembly. Thanks in advance.
  • CorbinDallas
    • Mar 2012
    • 56
    There is a single cable to disconnect in the back with rear upper cover removed. It will then just lift off the machine.
      • 22995
      Re: SHARP MX-C311 ADF REMOVAL
      There are also a couple of plastic catches at the bottom of the hinge posts. All you need to do is disconnect the cable, string the cable back through the hole, pull up, and flail about until it lets go.
      I must tell you though that the two main problems with this particular DF are:
      1) black plastic snaps designed to keep the top door shut, break off and get caught up in the turnaround. Requires major disassembly to remove the broken bits.
      2) Gray registrations rollers get dirty and slip. Clean all rollers. Requires major disassembly.
      These two will fix 9 of 10 calls. =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • ameritech
          • 96
          Thanks everyone.
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            I use a small flat tip screwdriver to assist in removing the catches as Blackcat mentioned. Have not had any break, and the scratches from the screwdriver remain on an area very likely to never be seen by the customer (if they do see it somehow, you have other issues on hand; like why is the customer trying that hard to take off the doc feed?).
            • austonrush
              Sharp & HP Tech
              • 234
              I think everyone forgot to mention the MXC-311/401 auto document feeder is a POS! lol
              • Akitu
                • Oct 2010
                • 2595
                I've had no problems with it? Other than customers knocking sensor flag arms out of place... Just keep it clean.
