MX-4101N with repeating image (black only)
  • CES_Imaging
    • Nov 2012
    • 65
    I've got an MX-4101N that repeats the black image. I've replaced the drum, which seems to help for a little while but it eventually comes back. I've also replaced the charge assembly and transfer belt, but it still eventually comes back. Does anybody know why?
    • 23008
    Re: MX-4101N with repeating image (black only)
    At what interval does the image repeat? =^..^=
    • Jhonjon
      • Sep 2013
      • 208
      I've encountered a excess toner (K) in the DV unit sometimes shadows the image and if pass to fuser it looks like double image.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          Mayhaps your transfer belt is not making proper contact with the cleaning assembly while staged for black?
          • faxman28
            • 435
            check discharge lamp and clear plastic lens in drum unit
            • CES_Imaging
              • Nov 2012
              • 65
              I replaced the entire drum unit. Since I did replace the drum in doing this, the problem went away again. I'll post again if the issue comes back.
                • 23008
                So, do you think it was a drum cleaning issue? Blade, charge memory, or charge cleaning?
                No pressure, just your opinion. =^..^=
