Toner dump AR-M455U
  • Ray Gates
    • Aug 2013
    • 33
    [Misc] Toner dump AR-M455U
    I just did two 200,000 service on a couple machines. The first went well but the second is a mess. When I opened it up toner was everywhere to include the bottom drawer, This was causing paper feed problems due to all the toner on the media. I cleaned up the machine, replace the DV, Drum, toner cartridge and fuser. As soon as I fireed it it made perfect copies and functioned great. No miss-feeds, jams or bad copies. When I opened up again toner was again all over the insides. Thinking maybe I installed a bad component I swapped out with the machine I had finished. It did not change anything on either machine. First machine was still operating perfect while second dumped toner.
    It appears the toner is coming from the rear of the drum where it attaches to the motor. Nothing appears to be damaged anywhere.
    Has anyone experience this with the AR455?
  • draph
    • 132
    Re: Toner dump AR-M455U
    Have you investigated the waste toner delivery system? I had an auger break so that it couldn't move the waste toner back to the cartridge.
      • 23010
      Ditto that. Remove the drum from the drum unit, then turn the cleaning unit drive coupler. I've seen them break in a variety of ways:
      1) The "D" shaped shaft could spin within the "D" shaped cutout in the coupler
      2) The "D" shaped shaft could break just beyond the coupler
      3) the teeth snap off of the coupler/gear
      4) The post that supports the tiny idler gear snaps off of the cleaning unit main body.
      5) The tiny idler gear loses teeth
      6) The short auger at the front of the cleaning unit snaps in half
      When you confirm it, the best solution is to order the cleaning unit assembly. =^..^=
      • sharptech1
        • Oct 2011
        • 163
        you sure the corona isn't broke?
        • draph
          • 132
          This unit doesn't use any coronas.
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            Noted in OP's post that [s]he did not change transfer roller. Worn transfer roller will pull extra toner and disperse it all over the drum cavity.
              • 23010
              True that. And if the transfer roller gear is worn, it will pull developer. =^..^=
              • draph
                • 132
                But if a 200K maintenance was done the transfer roller would have been included with the kit. Right?
                  • 23010
                  Roller, yes. Gear, no. They typically last only 2 PM cycles. =^..^=
