Frontier faxing
  • MHeon71
    • Oct 2008
    • 490
    Frontier faxing
    Have a client that would like to fax legal size paper. It keeps cutting off 3" and believe it is thinking it is letter paper. Really would like to get it to figure out paper size on its own.
    I have been able to get it to copy to the correct paper size but I cannot get the fax to determine the correct size.
    Am I missing something?
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: Frontier faxing
    Without length sensors in doc feeder, I believe you have to tell machine what the original size is.
    I don't think there are sensors in the paper path that reads the beginning and ending of a page, but I haven't researched that yet.
      • 23010
      Re: Frontier faxing
      Most machines with fax functionality are defaulted to detect the original size of only the first original, then assume that all following originals are the same size. You see, detecting the size of each original slows down the scanning process. On most MFP's you can enable a function called Mixed Originals, which means that it will check each original for size, but will be just a little slower scanning.
      So most likely the cover sheet is LTR-R and the rest of the sheets are LGL. The machine assumes that all the pages are the same size as the first (LTR-R), then clips the last 3" from each following page.
      Another option is to print up some legal sized cover sheets. =^..^=
      • MHeon71
        • Oct 2008
        • 490
        Re: Frontier faxing
        Thanks Zootech and Blackcat. I will give the legal cover letter a try.
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          Re: Frontier faxing
          The MXC311 has an auto detect size feature, just be sure the original size when in the fax screen is set as such.
          The MXC312 on the other hand, does not have auto detect size; quite the pain in the ass for the customers to have to specify legal every time.
