my dv powder is finishing to the end of life and my texts are printed relatively pale but without any copy quality (no line or dirties or spot)
then I executing the code 25 then 01 manual
after restarting the machine the spot appeared on the following picture is showed up on the copies
then I replace the DV powder with new one
executing 25 # 2 based on the instruction of service manual
all thing ok except copy quality and the one line excess and some dirties was appeared on the copies
my pale copying was eliminated with replace dv powder
I change blade of drum and cleaning some part of drum unit
but above problem still exist
it must be noted that some toner leaked and collected on one side of drum unit and poured to down
thanks a lot for your suggested solution and troobleshooting bad copy quality?
