MX 2640 F2-74
  • Larhal
    • 625
    [Error Code] MX 2640 F2-74
    Hi All,
    We have moved into Sharp machines. I really do not know them.
    We did an install of 4 MX2640 machines and I have had problems with 2 of them. We followed the setup procedure to the T and used Original toner.
    The machines started up OK and loaded some toner. When we started to copy 10-15 pages to test the machines set off F2-74 error codes.
    Scrum error toner cartridge K.
    We shut off the machines and replaced the Black cartridges. The machine came up with the codes again. Couldn't clear the codes any way.
    Wasted 2 Original cartridges.
    What did I do wrong? How can I clear the code?
    Thanks for any input,
    Larhal
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
  • divad2k1
    • Sep 2010
    • 147
    Re: MX 2640 F2-77
    Are you sure f2-77 refer to the black toner cartridge ?
    • Larhal
      • 625
      Re: MX 2640 F2-77
      No I am sorry F2-74 was the code, Kind of frazzled from this.
      Larhal
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        Re: MX 2640 F2-74
        From Sharp Search:
        1:
        Date Added 13/12/2012
        Model(s) Covered MX2600N, MX3100N, MX4100, MX4101, MX4112N, MX5000, MX5001, MX5112N
        Query F2-74, F2-75, F2-76 and F2-77
        Advice Check and replace PTC assy
        2:
        Date Added 08/08/2011
        Model(s) Covered MX2310U, MX2610N, MX3110N, MX3111U
        Query Errors C4-00, F2-74, F2-76, F2-77 after installation
        Advice The unit would jam after a few copies and or go into a C code. It may also exhibit poor copies and wont calibrate.
        You may also hear an electrical noise comming from the machine. The problem was due to the HVT unit not being pushed all the way into its plastic holding locks. The board on the rear frame of the unit is held into place by plastic hooks. Once the PWB was reseated the noise went away and the unit worked perfectly. There are springs on the back of the HVT unit that need to make correct contact to provide the voltages to high voltage areas.
        3:
        Date Added 29/11/2011
        Model(s) Covered MX2310U, MX2610N, MX3110N, MX3111U, MX3610N
        Advice Poor contact between TC PWB and the PTC corotron
        Please refer to attached bulletin:
        MX2610N-MX3110N-MX3610N440.pdf
        • fatfingers73
          • Feb 2013
          • 219
          Re: MX 2640 F2-74
          Check the gears on the toners. I always turn them a few times by hand and error goes away.
          • Larhal
            • 625
            Re: MX 2640 F2-74
            Already tried the gears. shook the hell out of the cartridge also. all turned OK.
            Cannot clear F2-74 code? What am I doing wrong?
            Larhal
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              Re: MX 2640 F2-74
              Did you read the above posts, stating it was the PTC Ion unit or the HVPWB?
              • Larhal
                • 625
                Re: MX 2640 F2-74
                Yes I did and checked them out. I could not find any discrepancy. Keep in mind these 2 machines are new just out of the box.
                Larhal
                Larhal
                • spanky
                  • Sep 2012
                  • 468
                  Re: MX 2640 F2-74
                  have you tried flashing the firmware?
                  • Larhal
                    • 625
                    Re: MX 2640 F2-74
                    Hi,
                    I have re flashed the firmware with no success. still can clear the code.
                    Boss is going to go to sharp for this. cant figure this out.
                    larhal
                    Larhal
                    • mojorolla
                      The Wolf
                      • 2639
                      Re: MX 2640 F2-74
                      Are you by chance moving the same toner cart from one machine to the next?
                      I have seen that scenario give CRUM errors.
                      • Larhal
                        • 625
                        Re: MX 2640 F2-74
                        No, we used 2 sets of new original cartridges for each machine.
                        Larhal
                        • piculito
                          Have you check dv
