lower cleaning roller
  • rods
    • 23
    What do you guys use to clean the lower cleaning roller in mx3100n
  • MHeon71
    • Oct 2008
    • 489
    Re: lower cleaning roller
    I would replace it. But if you have to clean it? I guess, I would try a knife or flathead screwdriver, if is seriously coated.
    • axyun
      • Aug 2007
      • 1323
      On a call when I don't have a replacement and metal cleaning roller is encrusted with toner I have used Blow OFF/Rubber Rejuvenator and paper towels or rag. Frank
      • draph
        • 132
        I first use a knife to scrape of the thick areas. Then I pull out the trusty 100 grit sandpaper I always carry.
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          I remove the stupid cleaning roller altogether; does nothing but cause problems anyways.
          • onetek
            • 318
            Lol .. so do I!
            • draph
              • 132
              Probably a pretty good idea after all.
              • axyun
                • Aug 2007
                • 1323
                That's an option I'll consider in future.Frank
                • mojorolla
                  The Wolf
                  • 2627
                  We have been doing this for years. Sharp should change the description to "lower destruction roller"
                  • igi
                    • 1507
                    if the waste toner bottle fails
                    the lower roller will collect
