MX-2615 SHARP.
  • piculito
    [Dead] MX-2615 SHARP.
    I have fans on and green light at ops panel. Sharp service suggested replacing SD card boot along with Flash boot as well. This did not fix it. I'VE also tried starting up on firmware recovery mode but still no boot. Any help would be nice.
  • bilyahn
    • Dec 2006
    • 1470
    Re: MX-2615 SHARP.
    Did you replace the memory modules? Have had them cause this problem. Swap them around and see if there is any change if you don't have replacement ones.
    Good luck.
    Bil
    • mojorolla
      The Wolf
      • 2630
      Re: MX-2615 SHARP.
      I currently have a 4141 with the same symptoms. I too have replace CF and SD cards at Sharps suggestion with no luck. Ordered the PCU board, but in typical Sharp fashion as of late, it is backordered.
      • JustManuals
        • Jan 2006
        • 9838
        Re: MX-2615 SHARP.
        This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
        Paul@justmanuals.com
        • CorbinDallas
          • Mar 2012
          • 56
          There is troubleshooting section in the service manual that tells how to troubleshoot dead machine by led lights on the MFP board.
          • TechGeek
            • 158
            Re: MX-2615 SHARP.
            I have a 5141 doing the same thing has anyone figured out what the fix is yet?
            • bdcrandall13
              • Sep 2010
              • 236
              Re: MX-2615 SHARP.
              These types of issues are generally caused by memory. There is a bulletin titled "How to troublshoot a dead machine." I suggest reading over that. Also, check the HDD.
              • jp74msj55
                • Oct 2014
                • 151
                Re: MX-2615 SHARP.
                Had MFP Control pcb board bad on Frontier series with same problem. May be your fix.
