mx-7040 not getting red color
  • abbas
    • 39
    [CQ] mx-7040 not getting red color
    dear friends;
    mx-7040 not getting red color. i tryed to calibrate color and try to adjest sim 50-22 44-2 63-3 (5) 46-74 again same problem. anybody can help me.
  • draph
    • 132
    Re: mx-7040 not getting red color
    Originally posted by abbas
    dear friends;
    What else have you done? Have you verified that the magenta shutter is opening? What's the page count? How old is the ETB?
    • abbas
      • 39
      its a new mechine color calibration is done . itb new. 6000 copies only cleaned color calibration sensors.how to chk the lsu shetter what is the simulation
      • draph
        • 132
        You couldn't have done a proper calibration if you had no magenta to begin with. You need to first fix your problem and then do a full calibration.
        The sim for checking shutters is in the manual. You must have one.
        • Silvertoast
          • Feb 2010
          • 270
          make sure the color lift rollers in the primary transfer are not broken and that they lift up and down properly. if the one for magenta isnt lifting you will not have the color.
          the other possibility is stated above reguarding the lsu shutter (i have never came across this myself but others have) my experience is its usually the transfer roller
          after you fix this issue it very important to redo the complete calibration since it was done without the magenta working. i can imagine it is all out of whack now.
          • Silvertoast
            • Feb 2010
            • 270
            i know you stated that you replaced the transfer, but they get damaged in shipping all of the time
            • Sharptech0892
              • Aug 2011
              • 77
              Also check dv clutch, have had 2 fail on us. easy test is switch clutches around.
