Sharp MX-2640
  • Sharptech0892
    • Aug 2011
    • 79
    Sharp MX-2640
    Has anyone had a issue with e7-93 code after replacing sd card on a mx-2640? Thanks in advance.
  • faxman28
    • 435
    Re: Sharp MX-2640
    e7-93 deals with image memory , (fax image memory) . sd card has fax image memory, according to service manual, when replacing sd card , a firmware update should be done and fax memory clear 66-10 should be done. Also have seen the write protect switch on sd card get set to on and this will cause errors, as the board can't talk to sd card.
    • Sharptech0892
      • Aug 2011
      • 79
      Re: Sharp MX-2640
      We have replaced dimm memory, hdd, mfp-pwb, compactflash and sd card per sharp they don't have faxe on this machine it only happens when printing firmware has been updated more the once.
      • mojorolla
        The Wolf
        • 2626
        Re: Sharp MX-2640
        Try dumping print memory with SIM 67-17. Be sure to clone the machine as the memory dump will also default smtp, domain name, and print port settings.
        • Sharptech0892
          • Aug 2011
          • 79
          Re: Sharp MX-2640
          Copier was brought into shop and is working fine, so I may be issue ssomewhere in network, file not sure.
