MX-M200D print problems
  • harps05
    Field Service Engineer
    • Mar 2012
    • 111
    Look forward to your ideas.
    Thnx20140502_085102.pdf
    • 22995
    Re: MX-M200D print problems
    It looks like primary transfer cleaning to me. =^..^=
    • bilyahn
      • Dec 2006
      • 1470
      Have not seen this on the MXM200 but on older machines it has been caused by the drum unit. If you have a spare I'd swap it out and see if it makes any difference.
      Good luck.
      Bil
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Machine has a transfer roller here, blackcat. OP said he replaced drum and cleaning blade, but not charge... I've seen a dirty charge do this exact same thing on the exact same model. In my case it was caused by a hair on the sawtooth grid.
        • bilyahn
          • Dec 2006
          • 1470
          Yea, totally missed he replaced the drum! Twice!!!!!!!!
          • harps05
            • Mar 2012
            • 111
            Got it sorted.
            Blackcat was on the mark. There was a biuld up of toner inside the guard at the base of the transfer unit on the side door. So a thorough wipe and clean of the area did the job.
            Thnx for the input Guys
              • 22995
              Congratulations on your success! Thanks for following up. =^..^=
              • chlarsen
                • Sep 2019
                • 2
                Same machine, different problem.
                I get sample.jpg"ghosts" while photocopying or printing as in the attached samples. There is no error message whatsoever, and the machine has been well maintained. Any thoughts, ideas? Thank you so much!
                Chris
                  • 22995
                  It's a black drum cleaning issue. You should be able to identify this condition easily on inspection. =^..^=
                  • chlarsen
                    • Sep 2019
                    • 2
                    Thank you so much for your reply. Please let me check this out, I will feed back!
