Address Book Size
  • teklife256
    • Sep 2012
    • 164
    Address Book Size
    Working on an MX-3501N and a customer has seemed to have reached the maximum number contacts allowed in the address book. There are 999 contacts entered and this particular customer would like to primarily enter many more fax numbers. Is there a work around or a way to increase the number of entries allowed? More memory or a programming tweak? Perhaps someone has an idea or solution they would be willing to share. We have entered contacts into groups but that does not free up any space.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Address Book Size
    If the copier is on their network they could try the lan fax driver, it has its own address book; I don't believe it has a limit.
    Either that or setup LDAP, and have the device search the LDAP server.
    • teklife256
      • Sep 2012
      • 164
      It's a two man office operation without a true server or LDAP. LAN fax driver? Will search idnc for that.
      • CorbinDallas
        • Mar 2012
        • 56
        Specification on that series. 999 one touch buttons. 500 group keys. 200 ftp/desktop/smb.
        • teklife256
          • Sep 2012
          • 164
          Lan fax driver? Can you elaborate?
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Sharp call it a PC-Fax driver, can be found on one of their driver sites. Allows you to print a document directly to the fax unit, sending it over the fax line. You can create multiple address books with multiple addresses each, a lot more than the machine can hold internally.
            • teklife256
              • Sep 2012
              • 164
              On the Sharp IDNC site I don't see any instructions on how to operate the pc-fax. I downloaded the driver but don't see literature on use.
              • faxman28
                • 436
                just install as a printer. then when you "print" to the pc-fax driver, a window pops up where you enter phone number and also can setup the address book. also should be in user guide.
                • Akitu
                  Legendary Frost Spec Tech
                  • Oct 2010
                  • 2595
                  I do believe PC faxing requires an optional addition to the machine as well...
                  • faxman28
                    • 436
                    fax kit, but in his original post ," user wanted to add many more fax numbers" made the assumption there was a fax kit involved.
                    • Akitu
                      • Oct 2010
                      • 2595
                      Yes, fax kit was the original intent I garnered from OP's post, however at the mention of PC Faxing I just made it noted that PC faxing requires the MXFWX1 PC Fax expansion kit.
                      • faxman28
                        • 436
                        that is the internet fax kit, plain pc-fax just requires the fax kit. to pc-internet fax you need internet fax kit.
                        from service manual mx 3500 pg 2-9 PC-Fax Send Yes (with Fax equipped)
                        Maximim of 64 digits for Fax number (including
                        sub-address and passcode
                        • Akitu
                          • Oct 2010
                          • 2595
                          I stand corrected. Can you tell I've never had to install one?
                          • faxman28
                            • 436
                            when I was at the K company in the late 90's early 2000's internet fax was kinda of hot for all of 5 minutes. I don't know anyone that uses internet fax now. send a fax or send an email. we can screw everyone up and throw in inbound routing into the mix.
                            • Akitu
                              • Oct 2010
                              • 2595
                              The local cash stores here actually do internet faxing on their Samsungs. They were every bit as confused as I was when they first found out about it.
