Fuser flat spot
  • rods
    • 23
    Fuser flat spot
    I have a new Mx4141 which has been sitting in the show room for 5 months, I suspect it was not turned off properly and has developed a flat spot on the fuser.Would any of you guys have a solution to this other then to install fuser kit.I have tried running fuser for about an hour but that didn't help.Copier has 75 copies on it
  • draph
    • 132
    Re: Fuser flat spot
    No, you are going to be re-building a fuser. Have yet to work on that model. Does it have pressure release levers lot other Sharps. Time to teach your sales people how to use them if it does.
    • ZOOTECH
      Senior member of CRS
      • 3375
      Re: Fuser flat spot
      This model does have a fuser release motor, and without the proper shutdown will cause a flat spot that may or may not work it's way out.
      NOTE: First power down from the keyboard until the display is blank, than power down the main power switch - this gives the fuser release motor time to disengage the rollers.
        • 23010
        Re: Fuser flat spot
        Try just running it. I know, I know. It will sound like my 1972 Ford with the polyester snow tires in February. But I've seen a few that did round out again after some use.
        Most don't, but the most you can waste is a couple reams of paper and a little toner.
        By the way, the polyester snow tires do round out again once they've warmed up a little. It takes about 1.5 miles at -20F. =^..^=
        • DavePo
          • Jul 2008
          • 305
          Re: Fuser flat spot
          I am sure there are a few of us that can remember those old bias ply tires.
