MX-M453N No power
  • Ray Gates
    • Aug 2013
    • 33
    MX-M453N No power
    I have a machine that was operating one moment then quit. No power. It has power out of the AC PWB and when the main power switch is engaged power goes to HL PWB but thus far nothing else. DC PWB? Anyone know a way of testing the DC PWB without just swapping boards?
  • MHeon71
    • Oct 2008
    • 489
    Re: MX-M453N No power
    A schematic and multimeter. Make sure it is not something stupid like aux. power being off.
    • Toner Boy
      • Aug 2007
      • 365
      If you can't find the issue soon try removing the harness going to the paper feed drive unit or some other external components.
      • spanky
        • Sep 2012
        • 468
        See attached bulletin
        • mojorolla
          The Wolf
          • 2606
          I have had 2 of these models where machine comes up, screen is blank, and after 1 minute, the fans kick on.
          In both instances, it was a bad DIMM chip.
          • Ray Gates
            • Aug 2013
            • 33
            I found one 5 amp fuse on the DC PWB had failed. Of course it had to be the only one I could not see without removing the AC PWB. Now to watch it to see why it failed.
