MX-M260 Blowing Toner
  • mikeg1265
    • May 2014
    • 10
    [Misc] MX-M260 Blowing Toner
    Hello,
    I have an MX-M260 just blowing toner all through the copier. It was received in about a week ago from one of our customers. The tech assigned to fix the fuser issue with it decided it would be a good idea to put a AR-M317 fuser in it because he was impatient waiting for the correct fuser. He has been terminated as this wasn't the first time he's not followed procedure. I installed a new MX-M260 fuser in it and it started blowing toner all through the precess path. I changed the Drum, Blade, Developer, Main Charge, but no matter what I do, it won't stop dumping toner everywhere. Any help would be appreciated.
    Mike G.
  • Jhonjon
    • Sep 2013
    • 208
    Re: MX-M260 Blowing Toner
    I don't think that the fusing will cause of spreading toners to the machine. first, did the spill toner is mix by developer? if so its either you have a problem in DV unit, bias or HV. If only toner are spilling maybe you have an issue with the toner itself, perhaps compatible toner.
    • mikeg1265
      • May 2014
      • 10
      I will try another toner cartridge. DV is new however the DV unit itself is original. Strange tho, this machine is only 3 months old.
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        What kind of volume does it have and why was the fuser changed? Chances are your drum and charge assembly may be worn out if your volume is appropriate.
        • Vulkor
          • Jun 2009
          • 946
          What is the meter at on this machine? The Drum Unit and Developer Unit are to be replaced at 300K I do believe. I've seen toner BLOW out the LEFT fan opening if the toner cartridge isn't installed or meshed right.
