Sharp 2700n life remaining on the developer and drum units.
  • JackJar
    • Aug 2025
    Hello
    How can I check life remaining on the developer and drum units? Manuals do not say anything about it.
    Is it possible to check exactly toners level? Machine shows only for example 75-50%.
    Best Regards
  • walterman
    • 196
    Re: Sharp 2700n life remaining on the developer and drum units.
    According to my service manual, section 7, page 3, approximately 3/4 down the page, simulation blah, sub code 6... clearly states how to arrive at this end result. Sir, you clearly must not have the correct service manual... Sorry about your luck.
    • Toner Boy
      • Aug 2007
      • 366
      ...and no, 75-50% is what you are given unless you take them out and get a feel for how much toner is in the container.
      • MHeon71
        • Oct 2008
        • 489
        Consumable parts in the manual tells you the expected yield of the different maintenance parts.
        • JackJar
          Thank you for your help.
          Could yo tell me what does FUSER ACUM DAy 500/740 (from counter display 22-1) means please? Does it mean that Fuser Unit can be use for
          a) 740-500=240 days
          b) 500 days
          TOTAL BW 58000
          TOTAL COL 88000
          MAINTINANCE ALL 155000
          MAINTINANCE COL 90000
          Does it mean that next maintinance should be done when total count wil be 155000?
          • faxman28
            • 435
            a) 740-500=240 days
            b) 500 days
            TOTAL BW 58000
            TOTAL COL 88000
            fuser acum days all supplies are good for 740 days(sharp spec) sharp recommends after 2 years or xxxxxx copies to replace item.
            total bw and total color are just that, total output for color and bw. maint all is page count since last maint (includes bw and color count) at 155000 you are overdue or count was not reset. Sharp default maint count all is 100k. you are also overdue on color, default is 60k. black dev and drum pm are at 100k. maint all most times won't sync up with the black dev and drum pm. your dev and drum counts are in sim 22 also.
            Also have your local Sharp tech check out the copier if you are not seeing the maint. required message on the display, settings have been changed or turned off.
            • JackJar
              Thank you for replay.
              I understand that 740 is the limit but I am not sure what does 500/740 means. Does it mean 500 days left to next maint?
              All informations are displayed as you said (drum, dev, belt etc.. for example drum_life (Y) 056, TC1 BELT DAY 418/740, TC1 BELT 81818)
              In my opinion total bw means total output machine done (since purchase) not since last maint. Please correct me if I am wrong.
              Later, I will show you full display from 2 machines and then we can compare them.
              • MHeon71
                • Oct 2008
                • 489
                500 is the days since component was replaced.
                B/W total output is total output and same goes with color.
                Maintenance All, I do not pay to much attention to because I clear it at every call and something maybe needed before the maintenance all light comes up.
                I pay attention to the individual counters.
                The days, I may look at if the component is showing wear, machine has been sitting in warehouse or I have some CQ issues that seems unexplained. If the counter says 740/740, chances are, I will fight with machine less and just order necessary PM parts.
                • JackJar
                  Thank you everybody.
                  500/740 meqans that it was used for 500daysy sa 240days left
                  If anybody can help to explain what does
                  DRUM LIFE (B) 076
                  means
                  or DRUM LIFE (y) 056
                  PS sorry I did not read post above.
                  • Akitu
                    Legendary Frost Spec Tech
                    • Oct 2010
                    • 2595
                    All of these questions can be answered if you purchase a service manual.
                    • faxman28
                      • 435
                      DRUM LIFE (B) 076
                      means
                      drum life and dev life is shown percent used b 76% used, also drum , dev, and tc belts also count rotations(don't ask, you need degree in theoretical physics to figure it out).
                      • JackJar
                        Does anybody can confirm that DRUM LIFE (B) 076 means 76% used(24% left) please?
                        It is a bit strange that Counter shows DRUM LIFE the same for all colours
                        DRUM LIFE (B) 076
                        DRUM LIFE (Y) 056
                        DRUM LIFE (M) 056
                        DRUM LIFE (C) 056
                        DEV LIFE (B) 076
                        DEV LIFE (Y) 056
                        DEV LIFE (M) 056
                        DEV LIFE (C) 056
                        Thank you for any help
                        • harleyrider
                          • Oct 2011
                          • 348
                          What the f***. Buy and read the f****** manual.
                          • faxman28
                            • 435
                            DRUM LIFE (B) 076
                            DRUM LIFE (Y) 056
                            DRUM LIFE (M) 056
                            DRUM LIFE (C) 056
                            DEV LIFE (B) 076
                            DEV LIFE (Y) 056
                            DEV LIFE (M) 056
                            DEV LIFE (C) 056
                            if you don't like our answers then buy the damn manual and read it
                            • JackJar
                              I did not want upset anybody. I wanted get an information and explanation. Thank you for all answers. I do not have more questions
                              Regards
